Remember then the engine will need to be beefed up, including having the engine block o-ringed, a high volume oil pump, high quality synthetic oil like AMSOIL so the oil can withstand the very high temperatures a turbocharger creates, forged steel connecting rods and crankshaft would be a very good idea, increased cooling capacity, having the computer reprogrammed to deliver enough fuel so the engine doesn't run lean and burn up from the inside out and then there's the transmission upgrades too. An easy $5,000 + to do it right. It's probably less expensive and certainly far less hassle just to buy a vehicle that is already turbocharged right from the factory.
A supercharger might not be so expensive and would provide much better throttle response.
