my speedo goes up to 35 mph then it comes back down to 0 as you speed up. my question is. is it a problem with the cluster or the vss speed sensor. oh ita a 93 auto and the odometer seems to work normaly
Just to be sure, check your battery, voltage and fuses on your Toyota first. If you pull out the sensor for a look, do it carefully, otherwise you risk damaging the transmission. My best guess is that it's a sensor problem.
