I would advise against it. Is the bolt pattern the same? Are the tires load rating the same or better than the stock tires? What are width and aspect ratio of the tires? If the overall circumference of the wheel and tire are different, yes you will mess up the speedometer and the odometer. Its also possible you might run into fitment issues with the brakes. I'm sure there are other factors as well that more knowledgeable people can comment on.
