I shorted the 12 volt DC adaptor/receptacle when I plugged In a  faulty connector of a 12 volt air pump.
Now, neither the socket nor the USB is working.
I could find the underhood fuse box, but no fuse was in the diagram for the problem location(s).
I cannot see an under dash fuse box as I used to with the 2010 Corolla.
Now, in that under dash position I see some wiring..
Can anyone tell me if I am up against a) a fuse, b) a wiring issue, or c) the receptacle itself, or
d), some combination of the above?
I read somewhere that it is likely I'll have to replace the receptacle itself. If true, is that hard to do?
Thanks, and happy holidays !
Hal
Hal
