Here's a quick write-up about one of my favorite gadgets. It's a ScanGauge II. It plugs into the OBD (On-Board Diagnostics) port at the bottom of your dashboard. In the US every car or truck since 1998(?) must have an OBD II port located someplace (fairly) close to the steering wheel. The OBD port is the one which your or a Mechanic would normally plug a scan tool into in order to read (and clear) any trouble codes which may (or may not in some cases) illuminate your 'Check Engine' light.
However in addition to reading and clearing trouble codes the Scan Gauge II can also display data from a number of sensors on your car in real-time. Here's a list of what you can display, four items at a time:
+Closed loop/open loop status (relates to how the Oxygen sensor is or isn't being used)
+Manifold pressure
+Boost (if your engine is turbo or supercharged)
+Instant MPG
+Average fuel economy
+Trip fuel cost
+Gallons per hour
+MPH
+RPM
+Throttle Position Sensor status (what % your throttle is open)
+Water temperature
+Battery Voltage
+Intake air temperature
+Fuel pressure
+Ignition timing
+Engine loading (in percents)
+Horsepower
In addition I think the newest version of software has some features (such as trans temp) which my older unit doesn't have. My unit is about two years old. A software update can be had for $25 (I think) though I haven't pursued it. There are a LOT of features relating to MPG and trips which I haven't explored much. It's a simple device to move from vehicle-to-vehicle, and even has the capability of being used on Diesel engines (I've used it in my '11 F-450 with just a minimum of system changes). Here's some pics:
It comes with a users manual too.
It plugs in near where your hood release lives
You can scan for codes. My Scan Gauge seems quite at home in the space in front of the gear shift which in my car isn't an ashtray.
The four things I normally monitor while I drive.
Kevin
+Manifold pressure
+Instant MPG
+Trip fuel cost
+Gallons per hour
+MPH
+RPM
+Water temperature
+Battery Voltage
+Fuel pressure
+Ignition timing
+Horsepower
![](http://i33.photobucket.com/albums/d92/Kev250R/973CD705-D678-433B-A13C-D7E0DE3DB1DC-6404-000008DEB65B8F00_zps31142bf0.jpg)
![](http://i33.photobucket.com/albums/d92/Kev250R/7586CC62-EFB0-4264-B6D1-08F295DADC3A-6404-000008DEE1BFFF4A_zps5d039830.jpg)
![](http://i33.photobucket.com/albums/d92/Kev250R/16C02FCC-E5DC-466C-A1A3-ABAFCE6072A6-6404-000008DF4EF89E74_zpsbf014705.jpg)
![](http://i33.photobucket.com/albums/d92/Kev250R/5A07FC6F-7310-4564-B9DB-6B52FC6B637C-6404-000008DF1D394EFE_zps621bec9a.jpg)
Kevin
