Replacing engine mounts
Hey everyone! I recently replaced 3 of the 4 engine mounts. I replaced the driver's side, front, and passenger's side engine mounts. To be honest they obviously needed to be replaced but I haven't noticed a big difference in how much the engine vibrates. Any ideas on what else could be causing the engine to vibrate if the engine mounts have been replaced? I mean the entire car rattles while stopped with my foot on the brake or even in park. Also I made a video for each engine mount that I replaced and wanted to share them with everyone. Cheers!
Old spark plugs and pcv valve will cause the engine to choke and vibrate.
Rotate your tires and repressure them too, bad tires will cause engine vibration too.
Clean your MAF sensor too.
Bad tires will not cause vibration if you are not moving witch is op's problem.
