09 S model 1.8L 225,000 miles, bought used, ran great then out of the blue, flashing CEL, bad news. Stopped, waited 5 minutes and CEL light went off. I have a scanner and quite a bit of experience, codes 0302 and 0303, misfire on cylinders 2&3 appeared at exactly the same time. Checked for loose connections, good. The odds of 2 cylinders misfiring at the same time seem one in a million unless one cylinder sets off another cylinder. Thought it might be water in the gas as we've had huge amounts of ran and cheap gas stations usually never change filters as required. I added heet, only 10 miles driving but no CEL and no pending codes on the scanner. If it appears again, I'll change coil on plugs to see if 2&3 are bad, however can't find which cylinder is what #, is it 1-2-3-4 from the passenger side? Where can I find that or does someone know? With this many miles, likely had plugs changed but not coil on plug which is suspect. I can change the coils around to see if coil is bad next time I get a CEL but is there an ignition module somewhere, parts places don't show one listed, 2 misfires at the same time of failure is 1 in a million unless one caused the other to misfire and why does it run fine for now? $80 for coil aftermarket, $140 dealer. Odds of 2 spark plugs failing at the same time, 1 in a million also. What spark plugs is everyone replacing them with, Iridium or platinum? Any halp would be greatly appreciated. Thanks
