I have heard that the stock intake gasket for the Corolla can fail/leak, leading to erratic RPM. The revised gasket (orange in color, not black) fixes this problem. I have never had a problem with my own stock gasket but, in order to be preventative, I ordered the revised gasket. After installation I have experienced erratic RPM and it even stalled once.
I have checked and rechecked the seals, cleaned the intake manifold till it shines, and triple checked all the hoses, the intake boot, and bolts, making sure everything was nice and tight. Obviously there is still a seal problem somewhere. In installing the new gasket I was told that using throttle body cleaner would be sufficient; is there any sealant I should be using or oil to create a better seal?
