If the window "squeak" is when the window is moved down and up and if it looks as if the window is moving slower than usual (or binding), then you need to lubricate the glass run channels with silicone spray. If this does not work, then the ? is whether the glass run channels (which are rubber) are worn and need to be replaced or whether the window has somehow become misaligned and needs to be realigned.
