I believe Brothabear paid $90 for the oil and did it himself.
@brothabear - I was looking for a video like this one and couldn't find anything. Although I found videos that show how to change fluid on dipstickless A/T which is pretty similar with the overflow tube to drain excess oil once engine/transmission reaches temp and expands, I was surprised no one documented one on NA market 14-18 corollas. I might be the first one
This is so freaking easy from looking at it, take wheel off, I'm assuming you take the left wheel well plastic cover off to get to fill hole. There are few minor details I would like to know more about, but for the most part it's very doable. 08886 cvt fluid is expensive no matter how you look at it, did you need one or two bottles? Also, looks like you can get away with pouring the oil right in the fill hole as opposed to using a pump like you have to on most lexus/toyota A/T dipstick less cars. I'm so tempted to do it, 90 bucks vs 300 is a good deal for something this easy. I'm glad you decided to change the fluid. No oil is going to last 200k miles, and if it does, cvt components are most likely worn out more as opposed to cvt where oil was replaced.
I can figure out bolt sizes etc, did you turn on vehicle at any point after fill up and cycled through D, R, N, B a couple of times? Did you run the car until it reached temperature and released some of the fluid using that overfill plug once fluid expands when warm? I appreciate the post man!
