Make sure you start at the wheel furthest from the master cylinder and then work your way towards the front driver side.
I have always thought that this is the correct sequence.
But I am confused by the advice in the Haynes Manual, Toyota Corolla 2002 to Jan 2007, Page 9-2.
Bleeding, Sequence
If the complete system is to be bled, then it should be done working in the following sequence:
a) Left-hand front brake
b) Right-hand front brake
c) Left-hand rear brake
d) Right-hand rear brake
