Hi. Ok, so I read in the forums about the LED lights. So, I put the 5 cluster ones in my reverse lights. One of them must have been bad. Because it shorter out the reverse lights. I learned later that it knocked out a lot of things, including: Power Steering, Odometer, Speedometer, MPG reading, ABS, tracking control, Engine light. This included display lights. I found that under the steering wheel fuse box the 10A ECU-IG NO.2 was the culprit. Now all the fuses under the dash ohm'd out ok. And all the little ones under the hood are ok. But now I still have the engine light on, the traction control light on and the turn signals or hazards don't blink on the inside or outside of the car. But I hear it ticking. Any ideas would be Extremely Appreciated. Oh, and does putting LED bulbs inside and outside of the car VOID the warranty?  Thank you.
Todd
								Todd
