Hello Everybody! Well I don't really have a problem but more of a simple solution. So simple the dealership couldn't figure it out! Anyways the only way I could open my trunk was with the key in the keyhole or the keymote button, the inside lever would not work! This really troubled me as I couldnt open it fast when i needed to while i had the car running (lazy I know!) so I had them check the problem while getting my routine complimentary maintenance and they could not figure it out and asked me to make another appointment. Now this *probably* would have been free and covered by the warranty (I have had the car 1 year 2 months and it has 11k on it) but I could not find the time to take it in with my current busy work schedule and I didn't want to take the chance of them charging me (I am cheap!). I decided to follow the cable all the way until I found it in the trunk, I popped off the vinyl/cardboard looking cover
I then noticed something wrong
So I put it back in place and VOILA problem that has been plagueing me and stumped the dealership fixed so simple.
With that not being clipped in place when you pull the handle it pulls the cable to the side and the cable does not pull tight enough to release the trunk, when it is clipped it pulls it straight back far enough to pop the trunk!
Now I know this is such a simple and easy fix you may be saying "duh this is so easy why even bother posting this" But that is the exact reason I am posting this, because it is so simple and easy it was obviously overlooked. Hope this helps at least one person now or down the line!
