2010 ABS and Slip Indicator on After Brake Job.
I changed my front pads and bled all four wheels. Now my ABS and Slip Indicator light are on continuously. I've tried to reset them using this method:
as well as trying to do a zero point calibration using this method:
I've tried to reset with Tachyon Toyota software, but it doesn't find any codes. I've also tried disconnecting the battery for over 30 min. Nothing seems to work.
Am I doomed to have the dealer reset it?
No. All I did was replace pads and bleed the brakes at all four wheels. I didn't even remove the rotors because there was zero runout and they were still quite smooth. I am assuming the problem is that I did the brake bleed the old fashioned way, and didn't have the car in "Air Bleed" mode or anything like that, given that I do not have a Techstream.
