i have a 2004 Corolla and have been told by a mechanic that I need to replace my lower control arms because the bushings are dry rotted.
I had to buy 2 brand new front tires because the tread was cupped. They believed this was part of the cause I have also heard clunking from the front end as well.
Now my question is how do you get the lower control arm off on the drivers side?
I just attempted this and the front bolt is only a little over an inch from the transmission. I could remove the bolt from the rear bushing and the ball joint but I didn't want to take all the bolt and nuts out if I couldn't get that front bolt out.
Any help would be appreciated.
I didn't try the passenger side because the shop that just put the new tires on cross threaded two of the lug nuts on the studs. So I couldn't get the tire off.
