2003 corolla s crank no start
My corolla cranks but doesn't start. Did a diagnostic and it said the camshaft. I changed that, the crankshaft, new spark plugs, new battery, and new fuel pump and it still won't start. Does anyone have an idea what else could it be.
casmic
you meen the camshaft position sensor right. not replaced the actual camshaft? why you buy the pump, plugs, battery? did you check for spark at the coil pack and plug? did u make sure it wasnt geting fuel? this is the haddrdest ? to answer because of your lack of info and the amout of things that can cause a car not to start
