2003 with 205000 miles. Engine shuts off at highway speed. coast to a stop, put it in park and engine will restart immediately. Engine runs fine. There has been a code for a few years now with o2 sensors note reading close enough to each other. O2 sensors are not failed, and not a pluged converter, no poor run quality, no black smoke from over fueling, not the problem. No other codes logged. Crank and cam sensor ohmed out perfect, all connections are tight. I replaced ignition start switch (electrical side of key switch) seeing as how there was no other codes and it seemed to be mechanical and the only logical part that could make this happen. I was wrong, still dies once and a while. Nothing common when it happens, example, time, miles, temp, only highway speeds.
