Misfire cylinder 4 bought. A new coil pack. No change. Replaced spark plugs. . No change. Its running ruff & & the code said cylinder 4 misfire. Changed what I just stated above. And its still doing the same thing. Hesitation when I step on the gas and u can feel the misfire. When I unplug the fuel injector #4 there's no change in idle. So I swaped fuel injectors & the same thing no change in idle witch happens when I unplug the other ones. Volts are The same on every connector & resistance is the same for every injector.what could it be to cause a missfire? The cat? Vacuum leak? Erg valve? Like I said I unplug fuel injector. 4 and there is no change in idle. What could it be? Any input would be appreciated
