I just bought a 99 Corolla with 126k on the clock. I plan to change the oil/filter and transmission fluid. The radiator is new, so coolant shouldn't be an issue. The day I looked at it I noticed the clip on the wiring harness for the drivers side signal bulb was broke. I tried to hook it up but ended up blowing a fuse under the dash labeled "TAIL". I replaced it and took it home. Yesterday I noticed the exterior lights stay on all the time, so I found the DRL fuse block under the hood and shorted it out. The headlights turned off, BUT they wouldn't turn on by the switch inside the car. I checked all the fuses again and removed then reinserted the DRL main fuse. Everything was back the same now, with the exterior lights still staying on all the time until I pull the key out of the ignition. The issue now is the interior dash lights will work sometimes in relation to the stick on the steering column, but for the most part they never work or they just stay on, and the exterior lights are on all the time. I talked to a mechanic at Toyota. He said he has seen this issue before, and it would be 1 of 3 things 1.) Bad DRL relay 2.) Bad light switch on column 3.) Bad DRL brain box under dash. Any suggestions for this issue or any other concerns for this car? Thanks.
Also, before I change the transmission fluid, I want to make sure I use the correct fluid. Will any Dexron III from the parts store be okay.. Or do I NEED special lube from Toyota? And I noticed there is a filter inside the pan. Is the filter just a normal bolt up type (unbolt old, bolt new one in?) Thanks.
