I was considering purchasing one of these cars and in doing a search on a 2001 Corolla at http://www.CarComplaints.com, I discovered that this generation of Corolla apparently is notorious for very high oil consumption.
Using Google, doing a keyword search -> Corolla, Burning Oil, I discovered there are many articles about this issue. Apparently the design temperature for the pistons in this engine was 120 degrees Celsius and the actual temperatures reached are 160 degrees Celsius, which causes the petroleum oil to sludge up and carbon to accumulate in the piston oil holes that allow oil to flow to the piston rings. This blocks those oil holes, preventing oil from getting to the piston rings and subsequently the piston rings wear very, very quickly, then allowing oil to be able to slip past the piston rings, into the combustion chamber and out the exhaust. Toyota has addressed this issue with an updated piston design with more oil holes in the piston.
To verify if your Corolla has this problem, quickly rev the engine up to 4,000+ rpm, release the accelerator and back several times and then look to see if a blue cloud of smoke has been created from the tailpipe of the car. Blue smoke equals oil burning and a lot of it.
This problem takes time to appear, as the oil holes in the pistons take time to get plugged up with sludge and carbon from petroleum oils. Top quality synthetic oils are far, far more resistant to the degrading affects of hot engine temperatures, (such as sludge and carbon build up).
The part number for the redesigned pistons is Toyota part # 13101-22142.
I was majorly disappointed to learn of this problem and that Toyota isn't stepping up to the plate, recalling these engines and rebuilding them at no charge. It would seem a class action lawsuit may be in order.
