Use Dexron type ATF, I personally like "Castrol Transmax Import Multi-Vehicle", you can find it cheap at Walmart. I would drain and fill, yes. Don't flush unless you've done regular fluid changes to that transmission, otherwise it might start slipping from the clean fluid (it's weird, but if you understand how it works you'll know why). Hope this helps!
