Hi. All 4 struts and coil springs need replacement on my 1995 Corolla DX wagon, 1.8 liter engine. I'm having a major issue finding the parts. The issue is that they are readily available for the sedans, but not the wagons. I know why - as you all know - the 93-96 wagons are really rare, and the manufacturers like Monroe, Delco, and KYB just didn't figure it was worth producing product for the .01 % of the Corolla market represented by the DX wagon model.
I did call all the above manufacturers and I was told no, I can't use the sedan strut assemblies, or even the separate struts and coil springs, from the sedans and put them onto the wagon. It makes sense - the wagon is significantly heavier, both unloaded and of course with the typical loads wagon drivers are carrying. So it's totally a different strut. Yet wagon struts aren't available! I've tried rock auto.com and many internet parts sellers. Only the dealers carry some of the parts (at a King's ransom) and even the dealers now "unavailable" now for the wagon coil springs.
First I tried to find the complete strut assembly because those are pre-assembled, pre-loaded complete with the coil springs, and they're much easier to install. Tons of availability for the sedans, but nothing for the wagon. (I should emphasize again - you're not supposed to use the sedan ones in the wagon. Totally different weight loads.) Then I tried buying just the strut, and then just the coil spring, separately, for the wagon. Again, none of the wagon springs or struts can be found.
Does anyone have a good source for wagon-specific strut components, mid-90s? There must be other wagon-eers who have had this difficulty. Thanks in advance for any leads or tips!
