What things to do to your corolla at 300,000km. Pre-emptively.
Fuel filter?
Cabin air filter (do these cars have these?)
Fuel pump? (Maybe not - probably buried within fuel tank)
Bleed brakes? Bleed clutch?
thanks
i just brought corolla wagon with 360k and need to do the following
rear struts
swaybar links
air valve below throttle body
pcv valve
cambelt
waterpump
spark plugs
airfliter
fuel filter
oil change and filter
brake fluid
clutch fluid
gearbox oil
All rubber parts need to be replaced, belts, timing belts, vacuum hoses, engine mounts, tires if old enough etc.
As with the previous post, that's about it, maybe the seats and carpet if too funky. :)
