carlile92 - One of the keys to long transmission life is making sure the filter stays clean and unobstructed. Some people change the automatic transmission fluid, install a new filter and then just drive the car. That's fine with a newer car that doesn't have any deposits, residues, or metal filings inside the transmission yet, but with an older transmission with many miles it is a very good idea to change the transmission filter again within a few hundreds miles or so. The reasoning is that the new transmission fluid will help clean out the transmission of residues, etc., and plug up the new filter, which then restricts fluid flow to the transmission, causing it to fail. With transmission rebuilds over $2,000 + now, not changing the transmission filter again after a transmission service is completed I feel is too costly of a risk to take, unless someone were independently wealthy.
Transmission = $2,000 +. Transmission fluid filter = about $30. A no-brainer.
Below is a link to a Technical Service Bulletin from the Filter Manufacturers Council that discusses this very issue -
TSB-98-2 Transmission Fluid Evacuation Service
One of the things they discuss in this TSB is the frequency, (or lack thereof), of changing the automatic transmission filter -
Emphasis mine -
"Service manuals and textbooks on transmission service recommend that a transmission filter be inspected and replaced, if necessary,
as often as every 15,000 miles (24,140km), for severe service such as city driving, desert (hot dusty) driving, extreme cold, frequent short trips, trailer towing, and delivery service.
In normal operating conditions the manuals recommend to inspect and replace the filter at least every 30,000 miles (48,280km). Even the newer vehicles with 100,000 mile (160,934km) drive train service warranties, the manufacturer recommends filter replacement if the vehicle sees severe service conditions".
When you need the AMSOIL synthetic ATF
http://www.amsoil.com/shop/find/product/atf?zo=349698 , just let me know and I'll get you the prices we discussed via private messages.
Another very important factor with transmission fluid life and thus transmission life is heat. Aside from hitting a bridge abutment at 60 mph,
heat is the #1 enemy of automatic transmissions. AMSOIL synthetic automatic transmission fluid reduces transmission fluid temperatures and also is much more able to withstand high transmission temperatures. Below is a chart showing how increasing hot temperatures can dramatically affect transmission fluid and transmission life. I hope it formats correctly here. The first column indicates temperatures in deg. F. and the column to the right indicates how long the transmission fluid will last in miles when subjected to the various temperatures listed in the column to the left -
Automatic Transmission Life as it Relates
To Thermal Oxidation of the Fluid
Fluid Operating Transmission Life
Temperature (deg. F.) Expectancy (miles)
175 100,000
195 50,000
Varnishes Form --> 212 25,000
Seals Harden --> 235 12,000
Plates Slip -----> 255 6,250
275 3,000
Oil Forms Carbon -> 295 1,500
315 750
Above 300 deg. F., severe component distortion occurs.
Data courtesy of General Motors
Here is a link to a field test with a taxi cab fleet where AMSOIL synthetic ATF was put to the test for 180,000 miles of severe service use without ever changing the transmission fluid. The transmission is torn down, inspected and pictures of the transmission parts taken so you can see what they look like after 180,000 miles of severe service usage without changing the fluid -
Las Vegas Taxi Cab Field Study (G3118) (1.5MB PDF)
Here are some pictures of technical data on AMSOIL synthetic ATF -
