Tire Pressure
I own a 94 Corolla, Base Model, 4 Speed. I am trying to determine what the manufacture recommended tire pressure is for my vehicle. I have been told that this can be found in the door jamb, but it is not located there. I have also been told it can be found in the glove department on a sticker, however my sticker is faded and peeled away. Can anyone provide me with some help on this issue? Anyone got a picture of the sticker they can post? I don't know if it helps or not, but the tire size is: 175/65/R14. Thank you for any help you can provide.
SCQTT
Somewhere between 32 & 36 will work fine & I'm sure is the in line with what was originally recommended. Check your tires cold.....before you drive on them.
Higher pressures are going to cause your ride quality to suffer. Lower pressures are dangerous because the tire can overheat and fail. Underinflated tires will also contribute to reduced fuel economy and shorted tire life.
The max pressure is listed on the sidewall, but the only time you would want to approach using that kind of pressure is if you were running high speed, at or over your vehicles weight capacity, and during hot weather.
Check your tires pressures often, they all typically leak a little. You also need to keep an eye on them when cold weather hits, this can reduce the pressure 10%.
For motorcycle tires I like to see a 10% increase between a cold and hot tire based on the type of riding I am doing at that time. You get a little feel for this after a while. Let's say I am running a big, heavy, adventure bike loaded down with gear and I am making time on a hot summer day on the interstate @ 80+MPH - I may start with 42 - if I check it after a while I will be looking for 46-47...If the pressure is higher than that I am running it too low and letting it heat up too much. If the pressure is 43-45, I am running it too high and I might back it down a pound or two for better grip and ride.
I changed my car's tires to the most affordable ones and was advised to keep the tires at least 30 psi since it is not like the high-end tires durability. Mine is 185/65 R14, stock size.
