squishy sound from brake
I changed the front brake pads of my 2010 corolla and noticed that there was "squishy" sound from the passenger side whenever I pressed the brakes (with engine running). It is similar to the sound of air being released through a valve. I have also bled the brakes and checked for leaks. All looks fine. Took the car for a test drive and brakes work fine but squish noise still there. Anyone knows what's causing this?
casmic
if there no brake fluid coming out your fine. the pads need to break in to the rotor. This being said that you changed the brakes and bled the lines feeling confident enough at your job to git in it and drive.
casmic
wait i just re read that. the sound coming from pads or the pedal. if It the pedal, and it feels spongy when depressed. you didnt blead your brakes right. air in the lines. no-bueno
