Rear window diagnose
I have a 2006 corolla and the right rear window does not work with either button no noise when I push either button I checked the seals to make sure not stuck from lack of use as I haven't lowered this window in months Don't guess it is a fuse as all other windows work and not a fuse for the same reason? If the window seals were sticky would a window regulator part break when you hit the down switch? Do I need to replace the regulator? Have done them on other cars and hardest part is getting the door apart without breaking anything Anyone have some ideas? Thanks First time forum member, Mark
Well I dont know if it helps but Mine 2005 corolla had the same problem last year. The mechanic didn't open anything. He just hit with his hand on the inside panel twice and it started working. May it was stuck. I also had not used it for months.
