Junkyard would be best. You'd need the caliper mounting hardware, the calipers, I'd probably skip on the junkyard rotors and pads and buy those new, the spindles (maybe) and the brake distribution block (that is mounted on the firewall, if you trace the lines from the brake master cylinder you can't miss it).
That piece is especially critical. Drums and Discs require different pressure balancing and going right to rear disc brakes without changing that can cause lock-up of the rear brakes during what otherwise would be normal braking.
