EMAIL: ricardo.galluccio@gmail
PAYMENT PREFERENCE: CAD, Paypal, possibility to ship internationally
ITEM: Complete car or Part-Out (most parts fit 1993-2002)
PRICE: $4500 complete car or TBD for part-out
DESCRIPTION: 1995 AE101 Toyota Corolla Base
Body Mileage : 219000 kms
Mileage Since Rebuild/Modifications : Less than 500 kms
Engine : Fully Rebuilt 1,6L 4-Cylinder 4AGE 20-Valve « SilverTop » with adapted harness and ECU
Transmission : Fully Rebuilt 5-Speed manual
Options : - Manual doors
Engine Rebuild : - Full engine wash, sludge removal and de-carbonizing
Transmission Rebuild : - New synchros
Other Mechanical Rebuild (all OEM Toyota Parts) : - Fuel tank, straps, filler neck, pump, & filter
Upgrades and Modifications : - Konig Helium bronze 16 in wheels 4x100
- Manual windows
- Remote starter
- Clock
- Gauge cluster w/ RPM
- No A/C
- Very little rust
- Repainted block, valve cover, timing belt cover and intake cover
- All new seals
- TRD head gasket
- New OEM Toyota spark plugs, wires, distributor cap and rotor
- TODA high performance timing-belt
- New OEM Toyota water pump
- New OEM Toyota oil pump
- New OEM Toyota crank main bearings and connecting rod bearings
- Cylinders sleeved and pistons with new Original Toyota rings
- A/C compressor delete
- All new ARP bolts, nuts, studs
- All new seals
- New axle shafts
- Brass shifter cable bushings
- New master and slave cylinder
- All new fuel and brake lines
- 2 new subframes
- New front lower tables, ball joints, swaybar link kits
- New front knuckles, hubs and bearings
- New steering rack, high and low pressure lines
- New rear suspension arms and swaybar links
- New radiator
- New front calipers, proportioning valve and master cylinder
- New engine and transmission mounts
- 205/45R16 Bridgestone Potenza RE960
- Excedy lightweight flywheel and stage-2 clutch
- Performance intake and filter
- Hi-flow Magnaflow Catalytic converter
- Tanabe Hyper Tuner Medalion
- 2,25 in exhaust
- Strut-tower brace
- Tokico HP struts
- Suspension Techniques 1,5 in lowering springs
- Tein adjustable Pillowball upper mounts (top plates)
- Hotchkis front and rear adjustable swaybars
- TRD short-shifter
- MOMO carbon fiber and leather steering wheel
- Pioneer CD/AM/FM/MP3 head unit
- Orion 10 in subwoofer with enclosure
- Infinity Audio rear deck 3-way speakers
- Yonaka front racing seats
- TRD aluminum pedals
- Hawk brake pads
- M-Sport front drilled and slotted rotors
- Rear AE101 disc brake conversion with rebuilt calipers
- Project 'u' slotted rear discs
- Goodridge stainless steel braided brake lines
- Removed all logos
- Tinted taillights
- Tinted windows
- Clear front side markers and flashers
- Xenon-bulb headlights
- Handmade front grille and real facia
