Hi Everyone,
Does anyone happen to know if the wiring for the driver airbag and horn are part of the same wiring harness? A little while ago the drivers side airbag light came on and the local dealer said the issue was in the wires through the stearing column for the airbag sensor system. A shroter time ago the horn quit working and the fault was traced to the stearing column. So IF they are part of the same harness I maynbe able to cure two issue with on labor cost.
Thanks in advance!
Thanks in advance!
