A Antonio Mariani New Member Dec 28, 2017 #1 Dec 28, 2017 #1 Radio doesn't work after battery was changed. What should I do?
LoCoRolla New Member Dec 28, 2017 #2 Dec 28, 2017 #2 call a service dept at a local dealer, sounds like a pretty common problem. must need some codes or something
Chris Denton New Member Dec 28, 2017 #3 Dec 28, 2017 #3 Try pulling off the negative battery terminal for couple of minutes. See if that helps. Do you have the entune/Nav unit?
