Corolla 2014le
ahmadd
Hi ...does le contain genuine harness for fogs light? or i install all wires ..and pls how i do that im from iraq and delar so far ...and thanks for reply
The harness should already be there. If you remove the plastic access panel under the car where the fog lights go, you should see a connector.
You can buy a new turn signal switch with the fog light option and replace it.
Do lots of research before taking my word for it on the switch.
Also, YouTube!!
Jake
I have a 16 LE, I put factory style fogs in, no existing harness. The kit I purchased came with a harness and factory style switch
