Car lighter and radio doesn't work. Help!
I have a 96 Corolla base model and for years the car lighter and radio hasnt work. I believe they went out at the same time. I check the (yellow) 20 fuse labeled Cig/Radio by the driver's side kick panel and it looks good. Where else can I check?
if they both went out at the same time it likely is a fuse. couldn't hurt to swap that fuse just in case it looks good but isn't. thats a good 1 minute sanity check. Hopefully you're not in a situation where a wire has severed.
