J Joshua79 New Member Aug 22, 2016 #1 Aug 22, 2016 #1 2016 LE less than 12,000m Went to the station, worked fine. Fueled up, started car, no air. The fan kicks on now and again but nothing comes through the vents. Other noted behavior. When the car is started the unit dials itself up to max
JesseG New Member Aug 24, 2016 #2 Aug 24, 2016 #2 Sounds like it's time to visit the dealership. Do you have the Auto climate setting on? Just a suggestion but maybe disconnect the battery and see if it was just a programming glitch with the Auto setting?
klinetime574 New Member Aug 24, 2016 #3 Aug 24, 2016 #3 Does the LE have automatic climate control? Admittedly don't know much about the other trims. x2 I would take this to the dealer. Should definitely be covered under warranty.
Y yuppicide New Member Aug 29, 2016 #4 Aug 29, 2016 #4 Yes, LE has climate control. I have a 2014 which I think is LE as well and I've got climate control.
