I have a 95 Corolla 1.8 7afe 5 speed manual that is jerking bad under acceleration worst at full throttle . It started after my distributor went out . I replaced it with a new one and it started just hesitating right at 3,000-3,100 Rpms then I parked it and now it's worse jerking around 2,500 to about 3,400 then runs great all the way to redline through every gear if I keep the rpms high . I've also replaced the spark plug wires , plugs , ignition control module , tps sensor , map sensor . Crank shaft sensor . Only thing I can think of is the ecu . If it's parked I can usually get it to rev no problem it's really mostly when it's in gear and accelerating
No check engine light .
