93 Corolla DX, with 242K miles on it. Original owner.
I have a strange fuel consumption issue with this vehicle, and wanted to ask before starting to change anything out on it. Average commute is < 20 miles round trip each day. Used for mostly around town driving - no long trips, and in fact, seldom anything longer than 50 miles. Driving style is not significantly changed within the last 5 years.
I'm not using any super-accurate mileage calculation, but having driven the car for 23 years & putting at least $20,000 worth of fuel through it, I know what "normal" mileage should be. On a trip/commute (>= 25 miles one way), it has gotten at or slightly over 30 mpg throughout it's life. Around town mileage has been historically been around 27 mpg. The fuel capacity says it's 13.2 gallons, but when I fill up (from E on the fuel gauge), I have generally put between 11 - 11.5 gallons. When I fill up from the fuel gauge indicating a half-tank, it takes about 5.5-6 gallons max. Putting 5.5 - 6 gallons from E will put it at a half-tank. So, the fuel gauge seems to be generally accurate (or close enough).
Here's the consumption issue.
It's due to have the timing belt replaced after the first of the year, and I'd like to figure out what would cause the odd consumption pattern I've noticed. Some info:
Any ideas as to what might be causing this unusual consumption?
- The car sips gas throughout the first half tank after a fill up. Routinely, I get 180 miles out of the first 5.5 - 6 gallons, around 30-32 mpg. If I fill up again when the gauge shows a half tank, it takes between 5.5 - 6 gallons, and it will average around the same mpg.
- On the other half tank, I can get 100 miles from it, maybe up to about 125 miles, an average of 20-22 mpg. Filling to a half tank will repeat similar mileage. Anything over that amount (between 1/2 & 3/4 tank) will bump the mpg up slightly.
- The car uses a little bit of oil (maybe 1/2 quart over 3000 miles) & has been changed at 3,000-3,500 mile intervals its entire life.
- It idles fine and runs good & it starts every time, and has never had any issue like this.
- There is only a tiny puff of smoke when it cranks first thing after sitting overnight - it does not do it otherwise.
- Plugs have been changed since last timing belt (at 180,000 miles), but not recently. Best guess is 40,000 miles +/- on them. I cannot recall when/if I have changed plug wires, but it cannot be more than one time.
- The thermostat works fine. All belts and hoses get changed at the same time the timing belt (60,000 mile intervals).
- No known electrical issues.
- I think the O2 sensor has been changed, but cannot remember at what mileage. Best guess is between 120,000 and 150,000 miles.
- Decent (Hankook) all season tires, with approximately 30,000 miles on them, no unusual wear on them, rotated regularly and uniformly inflated.
- Fuel tank has the locking door on it & it works fine.
- There is no known gas leak anywhere, and no smell of gas.
- There is little to no change in the driving pattern as a tank of gas is consumed. Most often driven in the 30-45 mph range.
- Having put virtually every mile on it, and filled it thousands of times, I know the "normal" use mileage has been between 350-385 miles on a full tank (11 - 11.5 gal), with approximately 165-190 miles being a half-tank.
