Have a few questions on repair/replacement of the transmission. Last week my corolla started to shake and make a humming noise. I thought at first it was a wheel bearing. After troubleshooting I noticed that the passenger CV Half-Shaft was loose going into the gearbox. I replaced the half-shaft and this did not fix my issue. The half-shaft fits into the gearbox and is loose/sloppy. This is what is causing my vibrations/wooble/noise.
Is there a fix for this problem that does not involve removing the whole transmission?
It feels like the shaft input receptacle is loose.
Does the transmission need to replaced?
Where is a good place to find used transmissions.
I am currently stationed overseas in Europe.
